Hi,
how can I read/write an element of a non IEC variable (called with {}) with type structure when only the root is visible in zenon Logic and not every single element?
For IEC variables this works fine with e.g. Variable.Node
For non IEC variable its not working when i tried the following: {Non:IEC:Variable.Node} or {Non:IEC:Variable}.Node
Error: Unknown identifier
Is there any idea how this is possible without showing every node in zenon logic?
Thank you and best regards,
Thomas
