Using VSTA instead VBA V.6
Hello. I little confuse, because VBA Ver. 6 is deprecated MS technology. And MS suggest use VBA.NET, but in Zenon in most case i can't full functional replace VBA to new supper-puper .NET. Besides, in 64bit system some code not work properly, ActiveX Listview control not available. If you want use Event handler, for example left mouse click, Zenon show only list of VBA scripts. I can use action "execute function" and select VSTA macro, but this is macro call without parameter, such as Element. Can I call VSTA macro from legacy VBA?And in this way implement wrapper for Zenon? PS All above for Zenon 7.10 SP0.
This is a migrated post! Originally posted on 27.08.2013 by user hyper_sonic. Please be aware that information can be outdated.
