time filter of report for following archive
Hi,
I made an archive for ETM with 1min cycling scan and defined one day as Archive saving cycle, so it gave 1440 points per day for each variable and all of them in one file. Then I activated “New following archive†for calculating Maximum value of per day for previous data. My goal is creating monthly maximum data report. The new archive gives one point per day for each variable and I use its data for report. The report screen and its time filter have been designed for one month.
The monthly maximum data report works correctly in RT but on the other side, there is limitation in selecting day because you can choose only year and month in its time filter. The report shows since 1st to current day for
each month that you have been selected.
This is correct only for current month and not for previous months. I attached its screen shot as attachment.
the Zenon version is 6.22 SP1.
Is there any way for beginning report for previous months from 1st to end of month?
thanks
This is a migrated post! Originally posted on 20.01.2011 by user roberto1978. Please be aware that information can be outdated.
