Textbox and Send Button symbol
Hello,
I'd like to create a symbol like this:
I need not to send a value to the driver when it's write in the textbox, but when you press the button.
I'm almost at the end of the problem but I still need a little help. These are the steps I've made:
1) I've created the variable linked to the driver and a variable where put the textbox value
2) I've created the image with the numerical value object
3) I've created a combined elemet with 3 variables: the first one is a useless variable boolean(called junkvar) just for enabling the button function, the second and the third are the two varaibles I've created in point 1
4) I've write VBA code and linked to the LeftClickUp event
VBA Code:
Public Sub LeftClickUp_ShowName(obElem As Element)
Dim IndexItem As Integer
obElem.ItemVariable(1).Value = obElem.ItemVariable(2).Value
obElem.LeftClickUp
End Sub
5) Linked the code to the combined object event
6) Created the symbol
7) Insert the symbol in page and test
And here all works.
When I create the second button I've got (obviusly) the problem that when I press the combined element button all button change color (because the junkvar) is the same, I only use the linking rule editor for replacing the two variables working with field.
How can I resolve the problem? I've noticed that I can't use a normal button, can I? If I use it the VB code is referenced to the button which has only one variables inside.
Thanks and best regards
Luca
This is a migrated post! Originally posted on 17.10.2012 by user luca.bardon. Please be aware that information can be outdated.
