Subreports in Report Viewer
Hello,
I'm currently using Visual Studio for report viewer.
In trying to create a very long report definition file, I ran into a problem which restricts the report body height to be limited at 1155.6 cm.
I then looked into including multiple subreports in the main report.
As such I have created two report definition files:
In Visual Studio, I have inserted the subreport in the body:
added the subreport to the solution like so:
When I run the preview in Visual Studio, the subreport comes out fine.
However when run in Runtime, the following error message appears:
How can I fix this?
Thank you in advance.
edit: to my understanding, when opening a report definition file from the editor,
the solution in Visual Studio is just a temporary one and adding a subreport to the list does not save.
I would like to know if Runtime checks for a path for a subreport coded in the report definition file, and if so, where the default path is.
If this is not the problem, please describe what the problem is.
This is a migrated post! Originally posted on 02.03.2020 by user katamon. Please be aware that information can be outdated.
