Smart Object Question
Greetings all,
I'm currently working on a project and I want to use the Smart Object provided by Zenon to ease the engineering time.
However, I came into 2 problems while using the Template utility:
1) I cannot use Export/Import from CSV of variables within the Template, thus I cannot move variables from my main Project to the Template using CSV file. I'm using the XML approach to move variables but its tedious.
2) When I make a Symbol and uses a placeholder inside that Symbol and use the Link Rule to replace the placeholder with variables exist within the Template, the variables are not visible in Runtime as:
Is there a way to fix number 2 and a workaround for number 1 ?
Regards
