Set object to an imported XML file
Hello,
we are trying to edit some pictures in the editor using a wizard.
The wizard should import as many XML files of a reference picture as pictures of that type are needed in the project.
Once that pictures are imported, the elements in those pictures should be edited using the object properties (dynpicture -> elements -> element).
The problem is that only when the wizard is completed, is the object of the imported picture (dynPictures -> dynPicture ) available in the workspace.
Is it possible to edit those pictures without the wizard needed to be run twice?
Thanks in advance
rln
This is a migrated post! Originally posted on 11.07.2016 by user rln. Please be aware that information can be outdated.
    Disclaimer
