Server Client Problem
Good Afternoon,
My runtime project will not run as a server, I have two machines with 7.2 runtimes installed. I can remote transport and run the projects fine, if I do not have the network active option ticked and primary and standby server defined.
When I enable this option which is what I want. When checking the runtime VBA, the Net Type is set to 3(which is client I believe)
If do the same but to set my programming terminal, to be server then generate runtimes file and then run it, this works and the Net Type is set to 1.
Am is missing something?
Regards
Jim
This is a migrated post! Originally posted on 17.08.2015 by user james.tin@bmwgroup.com. Please be aware that information can be outdated.
    Disclaimer
