Hi,
I want to build simple visualization available only in web browsers (clients work on Linux system). Application is mostly based on bool variables but one function is different. I must build the selection list and variable linked to selected position must be changed after switching the button. The button is one and common for every position in the list. Since List Box is not supported by HTML Web Engine could someone give me advice how to do it around? What Zenon's function will be the best to use by the button?
Regards,
Krzysztof
