REMA and IEC870 timestamp question.
I have two questions.
IÂ'm running Zenon Energy Edition with IEC870 Driver.
Is it possible to "block" external timestamps for signals with "to big" time difference, compared to the zenon PC, If time is outside the limits, take local PC time instead?
I have on a few occasions, when restarting IED-devices connected to my RTU, received signals with totally wrong time, future date.
As a result the events triggered by the, signal always gets at the top of the event list, because the list is sorted by latest at the top.
Now I have a some events dated 2070-01-01, I would like to know if it is possible to remove the specific lines only, from the buffer, or do I have to remove the CEL file and start over.
I have imported most of my Variables from CSV file, and I have noticed that assigned REMA:s doesn’t work, (the Rema doesn’t execute) for some of my signals.
If I look in Zenon Editor, on the variables not working, the name of the REMA is in place and looks OK. Now to the strange thing, If I click on the button to assign a rema, browse for it, select it, and press OK. After compile it works.
I have tried to select all my variables using the same remas, and manually browse and select, but only one of the variables get fixed.
/Regards Tobias
This is a migrated post! Originally posted on 22.01.2020 by user Tobiasto. Please be aware that information can be outdated.
