Released properties of components can't be edited after grouping
Hi!
I am using property groups for shared properties in a component from the symbols library, in order to simplify the configuration after placing it on the screen.
However, for some reason, after grouping the released properties in property groups, the properties' values can't be changed anymore after placing the component into a screen. If I don't group the released properties, I can edit them with no problems.
If a select and deselect the component in the screen, some times I can edit one or two of the properties (any properties, not the same ones each time), but that is the fartest I was able to go.
I'm using Zenon 11 build 282289 64 bit. Attached is image of the grouped released properties of my component, with the default values from the library.
Any help regarding this issue would be very appreciated.
Thanks
