Regarding changing the Archive Start Time setting in zenon 14.
Hi, I currently using zenon 14 with Historian data archiving enabled. Historical data is already being stored and archived successfully.
I need to modify the Archive Start Time setting for an existing archive configuration. Before making this change, we would like to understand its impact on the existing historical data.
Could you please clarify the following:
  1. Will changing the Archive Start Time affect or delete any existing archived data?
  2. Will the Historian continue to access and display previously stored data after the change?
  3. Does changing the Archive Start Time create a new archive segment or archive structure?
  4. Are there any recommended precautions or backup procedures that should be performed before making this change?
  5. Are there any known issues related to timestamps, archive switching, or data retrieval after modifying the Archive Start Time?
    Disclaimer
