Reading RDA Array(Real Data Type) from Beckhoff Twincat NG Driver
Hello,
Our requirment is to capture live data from PLC (Real Data type) and capture it in Extended Trend. We have to capture live data for every 10 ms from the PLC. We have created RDA Array[50] inside the PLC of Real Data type and provided the data from Index [0] to Index[6] as per the format and from Index[7] to Index[50] real time data was passed. When we triggered the zeroth Index data is not captured in Archive Screen (.ARX file was not created in the folder path) and we cannot view anything in extended trend. But all the RDA Array[50] variables are communicating when observed in variable Diagnostics.
When we tried with Double Word data type, the archive is working and for every 10ms values are captured in the Archive screen and can be viewed in Extended trend Screen as well.
Can someone clarify whether any particular setting has to be done for capturing RDA array variable for Real data type and is there any Hardware specification to be considered.
I tested with the below provided Specifications
  • Zenon Version:7.60
  • Build Version:64404
  • Driver: BECKHNG
  • OS: Windows 8.1 Pro
  • RAM: 4GB
  • PLC: TWINCAT-XAE PLC 3.1.0.0
Thanks in advance.
This is a migrated post! Originally posted on 31.07.2020 by user Sriganesh. Please be aware that information can be outdated.
    Disclaimer
