Hello,
As the title says, I'm looking for the best and efficient way to apply project integration. I have 6 sub projects and 1 main project. I want to make a screen within the main project that link to the sub projects screens. Keep in mind that each project has their own configurations (different screen content, different headers, different footers, etc...).
Is it as simple as dragging the sub projects into the main project ? will my variables, drivers, screens, functions, etc from the sub projects be available to use in the main project?
I will add a button that will link to the main project selection screen so the user can go back and forth between projects with ease.
Also, my project require the use of the Historian module (archive data). Is it possible to use the main Historian module instead of using the module on each sub project ?
One more thing, can I use a Global Project to standardize all common things across the projects like Frames, Styles, Equipment Models etc. ??
Regards.
