Process Gateway and IEC870slave
Hi there!
My first question is where is zenProcGateway.ini ? I opened the Process Gateway and chose IEC870slave as the module. Due to some problems, I decided to change it. However it's set on the previous configuration and I cannot find the zenProcGateway.ini file anywhere in the folder related to zenon. Maybe the university does not have a license for it yet and that's why I cannot find it. So if anyone could help me, I would be very grateful. Thanks
Second question is can Process Gateway be used to share variables from one runtime with another one that has started on another machine? The idea is that a machine should be able to capture variables from another machine's runtime so it can be used for its own design. So I stumbled upon Process Gateway and I thought maybe it could be used for that purpose. Thanks again for your guidance.
Regards
Mehrdad
This is a migrated post! Originally posted on 30.10.2014 by user mehrdad66. Please be aware that information can be outdated.
    Disclaimer
