Proble with Bachmann M1 Protocol
Hi Guys
I have a problem while extracting signals from Bachmann protocol.
I am having 10 wind turbines, and I need to communicate with all of them.I added the Bachmann Driver and configured all the turbines inside it.
If I Extract signal from one turbine, then there is no problem. If I try to extract the second I coudnt extract because the Variable name is already present inside zenon.
If I change the variable name of the first turbine and then the extract second it is extracting. But the values of the first turbine are not reporting to the zenon runtime since it polls with the varable name only!
Incase of other protocol we can give as symbolic address and change the variable name. But in this case what can I do?
Please share ur ideas.
Thanks in advance.
This is a migrated post! Originally posted on 06.08.2017 by user Praveen Kumar Karthikeyan. Please be aware that information can be outdated.
    Disclaimer
