Problem Process Gateway with GE SCADA software GENe
Hi
I have a problem for connection between 101 Process gateway and GE SCADA GENe dispatching centre?
I tested with process gateway by other software 101 master (Siemens IEC test ) or Triangle 101 master that it connected well with process gateway (signals, control...) but when I connected process gateway to GE SCADA GENe system. It cannot connected successfully. I see the log in GENe system, the command GI send very frequency. It show link connected, send GI after every 1 minute.
I think this problem from configuraton of GE system but they config to connect to other 101 slave, it worked fine.
Could you have any idea about it?
Brgds
This is a migrated post! Originally posted on 19.01.2018 by user mytom. Please be aware that information can be outdated.
    Disclaimer
