Problem of VBA environments: in conflict with MS-Office?
I encounter a problem after re-install my PC: the zenon editor (6.22 SP1) can’t start correctly after the installation of MS-Office..
1. I re-install my PC by using a Windows XP SP3;
2. Everything is OK when the installation of ZenOn 6.22 SP1, the editor works well;
3. After installation of MS-Office (either Office2007 or 2003), the editor is in trouble…
a. At first, it shows me a pop-up window:
Microsoft Visual Basic
License information for this component not found. You do not have an appropriate license to use this functionality in the design environment.
b. If I click “OKâ€, the editor will be started. But at the same time, one line of Visual Basic is highlighted automatically:
Private Sub ZenWorkspace_OnElementCreated(ByVal obElement As Element)
c. With the appaierence of an error message pop-up window:
Compile Error:
ActiveX component can’t create object
d. If I click “OKâ€, I will be blocked by a pop-up window without termination:
So, How do you think about it? How can I resolve this problem?
This is a migrated post! Originally posted on 13.01.2011 by user lephis. Please be aware that information can be outdated.
