I use Variable > Process Gateway > OPC UA gateway to set up the server .
Then I start it automatically or explicitly by separate function "Proccess Gateway Action" .
In both cases a small dialog window is started every time that allows changes to the configuration or even the shut down of the OPC server itself . There must be a way to hide this window . Please help !!!
