Note: 7.10 DVD Webclient "big setup" and zenadminsrv/zenlogsrv problem
Dear all.
In the near past, it happened that the Webclient-Installation (big setup package) from the actual zenon 7.10 DVD doesnÂ't install the zenadminsrv or zenlogsrv services correctly. -> Therefore the Webclient does not start.
(See also Article ID 195607 in the knowledge base on the service site)
It is a sporadic problem, so it does not show up on every system. Still we understand it is very annoying.
We already got a fix in the newer build version. (And i think, new Setup DVDs will be set up).
So if you encounter this problem please ask your nearby COPA-DATA Support Team for the Webclient Installation Packages of Build 6571 or higher.
This is a migrated post! Originally posted on 11.09.2013 by user christian.hayna. Please be aware that information can be outdated.
    Disclaimer
