Multi user variable administration
Hi,
I'm using Zenon 7.5 SP0 Build2596 64Bit.
While editing a structure data type I triggered the "variable Administration" option.
i saw in your manual "Distributed engineering" page 20 section 8.2.1 :
"In the special case of the variable administration the symbols are displayed slightly transparently, if the module has been checked out"
but the manual doesn't explain how to get out from this mode, I tried the "accept changes" option but with no success.
further more, when I try exiting the editor I get the popup windows that basically says that I didn't checked out although I accepted all the changes ..and when i press the "Accept changes" option in the window below, the program exits after several minutes.
then I open the editor again but I'm still "stuck" in the "variable Administration" mode ����
------UPDATE-----
I just Saw when I compile the project I get an error message "An error occurred while checking in element".
This is a migrated post! Originally posted on 17.11.2016 by user nkadishi. Please be aware that information can be outdated.
