multiuser project check in not possible (SQL error)
We successfully created a multiuser project, that worked fine.
But, since I am now at home, conection via VPN to the fab-network, it is not possible for me, to check in the variable module
I`m able to check out and in any other module and it is also possible to check out the variable module. only the check in is not possible.
The following error is shown:
"Cannot initialize the data source object of OLE DB provider "SQLNCLI11" for linked server (local zenon SQL server name)
SQLState is 42000
Error code is 7303OLE DB provider "SQLNCLI11" for linked server (local zenon SQL server name) returned message "Unable to complete login process due to delay in opening server connection".
SQLState is 01000
Error code is 7412 Execute command failed. Errorcode:11101
any Ideas how to fix this problem?
thx simsuniy
This is a migrated post! Originally posted on 17.09.2014 by user simsuniy. Please be aware that information can be outdated.
