Hi,
I have send Emails from Zenon with very specific header.
<STATIC_TEXT><DYNAMIC_TEXT>
Where <STATIC_TEXT> is always: 3613$1$
And <DYNAMIC_TEXT> is like:
0bfcb947-6db0-1f5f-816d-b5584d000033
I fought that I will add the static text in global options of the Message Control and then I will add Variable Value in project options of Message Control. Right now I have two problems:
1. After Static text is always `: ` like: 3613$1$: <DYNAMIC_TEXT> is it possible to somehow remove this?
2. I have a problem with adding value of internt STRING variable. When I've typed this:
%<NAME_OF_VAR>;
I've got exactly the same text in header, like: 3613$1$: %<NAME_OF_VAR>;
But when I type this:
$@Achtung;%<NAME_OF_VAR>;
I get this: 3613$1$:
Achtung---
Is there any solution that will meet the conditions of the header.
