Micom Px4x URCB/BRCB problem
I am trying to integrate a couple of Schneider/Areva Micom relays series 4, protocol 61850 to Zenon 6.51 SP0 build 5 system.
Connection to the devices is working. Polling mode is ok.
When I make a URCB available and start the Runtime the driver connects to the RCB and disables pooling of these variables /this is seen in debug mode/.
There was an "error 11" message, that was corrected by checking the "TrgOps" option in the driver settings. Everything seems ok, but it is not.
All variables, that have polling disabled are not available to the Runtime!
When using Numerical value to visualize the boolean variables there is no information, nor when trying to generate a signal from the protections.
This is the same with BRCB or URCB, with "TrgOps" option checked or not.
Tests are made with P145 and P645 protections. Settings with Micom S1 Studio.
RCB's are enabled, checked with IED Scout. The same RCB's, connected to an other client - SPRECON-E controller, are working correctly.
All suggestions are most welcome.
This is a migrated post! Originally posted on 14.05.2012 by user sstoilov@gmail.com. Please be aware that information can be outdated.
