Message control zenon6.ini
Hello,
I have noticed that the zenon6.ini file are not the same on the primary server and the standby server.
I am configuring an SMTP functionality and I noticed that I need to copy the [Message Control] section from zenon6.ini file on the editor PC to the zenon6.ini file on the SCADA server.
Should I copy this also on the standby server seeing that the zenon6.ini files are not identical?
If I don't copy it, will the standby server be able to send e-mails when the primary server crashes?
Kind regards,
Razvan
This is a migrated post! Originally posted on 15.11.2018 by user razvan.astefanoaei@engie.com. Please be aware that information can be outdated.
    Disclaimer
