hello,
i am working on a big
project where we work on B&R redundant PLC, the SCADA system is Zenon 14, the connection between the PLC’s and the SCADA is OPC UA with highest
level of encryption with certificates. the connection is made with one IP address
to both PLC’s (bonding + cluster).
when a redundancy
switch occur on the PLC the connection is lost for almost 20 seconds. (the PLC itself switch almost seamlessly)
what can i do to
reduce the time significantly, it is not acceptable to lose data for 20
seconds.
please let me know if
any more information needed.
thank you.
