Installation failed because can't find logs
Greetings,
I'm having an issue with installing zenon 15.
The reason in the generated logs indicated missing setup logs:
[26F4:2B8C][2026-05-15T13:30:26]i000: Setting hidden variable 'CDP_SQLADMINPW'
[26F4:2B8C][2026-05-15T13:30:26]i000: Bootstrapper has called CheckSqlServerRules
[26F4:2B8C][2026-05-15T13:30:26]i000: Bootstrapper has called StartProcessWithExitCode, ProcessPath: D:\Setup\SetupPrerequisites\Microsoft SQL Server 2022 Express, ProcessName: SETUP.exe, Arguments: /ACTION=RunRules /RULES=SCCCheckRules /Q /HIDECONSOLE
[26F4:2B8C][2026-05-15T13:30:28]i000:  - StartProcessWithExitCode returned '-532462766'
[26F4:2B8C][2026-05-15T13:30:28]i000: Setting string variable 'CDP_SQLCHECKERROR' to value '-532462766'
[26F4:2B8C][2026-05-15T13:30:28]e000:  - Error: Cannot find SQL Server setup logs
[26F4:2B8C][2026-05-15T13:30:28]e000: Error 0x80070643: UX aborted apply begin.
[26F4:2B8C][2026-05-15T13:30:28]i000: Bootstrapper has called MoveNext, status: -2147023293, restart: None
[26F4:2B8C][2026-05-15T13:30:28]i000: ============================ SUMMARY ================================
[26F4:2B8C][2026-05-15T13:30:28]i000: Installation failed
[26F4:2B8C][2026-05-15T13:30:28]i000: Error:    Cannot find SQL Server setup logs
Any help would be much appreciated.
