Import Tagname from .csv file
Hello
I am a beginner in VBA using.
I want to import parameter Tagname from csv file.
I read "Name" into variable tta_str and "Tagname" into descr, but I can not write Tagname into a variable.
It is working only if I put into Item(" variable name ").
thisProject.Variables.Item("XYZ").DynProperties("Tagname") = descr
If I use a VBA variable (tta_str)
thisProject.Variables.Item(tta_str).DynProperties("Tagname") = descr,
it is not working :confused:.
What do I do wrong?
Thanks Jaro
VBA Code:
Public Sub Jarosova()
Dim InputData
Dim tta_str, descr As String
Dim lengh As Integer
Open "c:\Temp\JAROSOVA_OPC.csv" For Input As #1
' Do While Not EOF(1)
Line Input #1, InputData
lengh = Mid(InputData, 1, 2)
tta_str = Mid(InputData, 4, Int(lengh))
descr = "Bratislava JaroÅ¡ov¡ " + Mid(InputData, Int(lengh + 5))
' working OK
thisProject.Variables.Item("ZS_BA_JAROSOVA_OPC.diRKL01FA11Vyp").DynProperties("Tagname") = descr
' not working !
tta_str = "ZS_BA_JAROSOVA_OPC.diRKL01FA11Vyp"
On Error Resume Next
On Error GoTo 0
' Loop
Close #1
End Sub
This is a migrated post! Originally posted on 22.06.2011 by user jaroslav.kral. Please be aware that information can be outdated.
