Importing variables and Client IED name in IEC850 driver configuration wizard
Hello everybody,
It's my first time using IEC850 driver configuration wizard (I usually configure it with online IED's) so I have a couple of questions about it:
1. I can't see any variable in the list so I can't import them. Maybe, I should import variables from the driver and select the SCD file using File browsing but I am not sure if it is the correct/best procedure.
2. Instances of RCB's has been configured for Client IED names in SCD file. I used to configure ClientLN.iedName in RCB assignment datasets (Client1 for SERVER_SCADA1, Client2 for SERVER_SCADA2). In wizard, I know Client IED name canÂ't be edited and it is always grayed (empty) but I noticed It can be edited in driver configuration (RCB assignment datasets->ClientLN.iedName) after finishing wizard configuration. If I go back to wizard, the Client IED name is visible now. It is OK this procedure?
I am sharing some screenshots with you. The version of zenon Energy Edition is 8.10.
I really appreciate your help.
Best regards,
Jose_Alejandro
This is a migrated post! Originally posted on 07.09.2020 by user Jose_Alejandro. Please be aware that information can be outdated.
