IEC 61850 driver problem reading XCBR/Pos/stVal
Hello everyone!
I have a problem with IEC 61850 driver. I've imported variables from an IED and enabled reports, everything works as it should with one exception. The driver reads different values of XCBR/Pos/stVal node than other software, for example IED Explorer. Below is a short table of what values are read by ZEE and IED Explorer.
The variable of interest was imported from IED with default settings which are shown in a screen below.
Changing reading method of the variable from report to polling didn't change anything. My question is if it's possible that IEC 61850 driver reads the variable value incorrectly? The device I'm connected to was developed and produced by my company, we didn't have any problems with it in other applications.
I'm using ZEE version 8.00 64 bit. Let me know if you need any further description/details to help me solve the issue.
This is a migrated post! Originally posted on 21.01.2020 by user Lukbla. Please be aware that information can be outdated.
