IEC 101 Slave: Master Connected and startup request
Hi,
I have a zenon logic project containing IEC60870S2 Slave profile.
I created a variable (TID=0, IOA=1) permits to understand if a Master is connected to the slave.
Problems are:
1)
when Master-Slave connection is up, value of the variable changes to 1.
when Master-Slave connection fails, value doesn't change to 0, it remains 1 also if Master is not connected: only closing and rebooting straton project, value of the variable change to 0.
I thought variable value returns to 0 when the connection ends.
2)
This is not a problem but a question.
In zenon logic, is it possible to delay IEC101 slave driver starting??
I use zenon logic like a gateway, I have a 61850 driver reads data from the field and gives it to 60870 slave. At the startup, 60870 Master receives invalid values because zenon logic didn't yet read 61850 values.
Thanks
This is a migrated post! Originally posted on 18.08.2016 by user steven.costantini. Please be aware that information can be outdated.
    Disclaimer
