I need a way to rollback a command that came from command processing due to a timeout.
I have a breaker that has been tripped. Someone mistakenly issues a close breaker command. The command times out. Now that command has already been written to the protective relay and when the 86 switch is reset the break executes the close unexpectedly.
I know how to setup the timeout so the timeout bit is set in the status after 5 seconds, but I do not know a way to write the current status to the command when this happens.
I am using the Energy Edition.
