How to use command processing for IEC 104 and IEC 101 process gateway?
Hi,
i want to check the command through process gateway using command processing with interlock check,
i am using IEC tester for executing the command. command is also executing without command processing and interlock check.
is there any setting need to enable in order to check the interlock?
here shown below which i configured
This is a migrated post! Originally posted on 09.01.2022 by user nura1987. Please be aware that information can be outdated.
    Disclaimer
