How to start and stop driver simulation project from runtime?
Hello, colleagues
In Editor there are 4 modes for driver configuration. I used driver for IEC60870-104 protocol. I use Straton for driver simulation project and in driver configuration I select mode “Simulation-programmed” for this case.
It work well. But I want to switch in “Simulation-programmed” mode from Runtime.
I set “Hardware” mode for driver in Editor and started Runtime. Can I switch driver to “Simulation-programmed” in Runtime? I tried to send function “Driver command -> driver in simulation mode” but Straton simulation project didn’t work after sending this command. And I couldn’t connect Straton to Runtime that debug my project. Can you say in which mode this function switch driver?
I use v7.00 build 5.
This is a migrated post! Originally posted on 06.06.2013 by user altera. Please be aware that information can be outdated.
