I am trying write more complicated function but i have a problem with find VBA project, for example (easy example to show problem)
Sub LookingForStringInEntire_VBA_project()
Dim vbProj As VBProject
Dim vbComp As VBComponent
Dim strToFind As String
Dim strModuleName As String
Dim strModuleCode As String
Dim test As Variant
Dim i As Long
' Str to find
strToFind = "my string"
' set reference to project VBA
Set vbProj = "What i should set here"
' look every module in set project
For Each vbComp In vbProj.VBComponents
' check if component is a module
If vbComp.Type = vbext_ct_StdModule Then
strModuleName = vbComp.Name
' set module's code
strModuleCode = vbComp.CodeModule.Lines(1, vbComp.CodeModule.CountOfLines)
' looking for string which you set
If InStr(1, strModuleCode, strToFind, vbTextCompare) > 0 Then
MsgBox "ok i found"
End If
End If
Next vbComp
' clean memory
Set vbProj = Nothing
Set vbComp = Nothing
End Sub
