I have a question regarding zenon 12 Engineering Studio and the use of the “Set value via” property set to “Program” on a screen element.
I configured a screen element so that when its value is set, zenon calls an external .exe file using the Set value via = Program option.
The external program is a custom application written in C#.
With this setup, zenon successfully passes the current value to the external program as a command-line argument, and the program can display and process that value.
However, I have not been able to determine how a modified or calculated value should be returned to zenon and written back to the variable:
Main method (void or int return) does not update the zenon variable.My goal is to implement a custom date/time input interface that is not available as a standard zenon input control.
For that purpose, I would like to use an external C# executable to:
Is there a supported or documented way for an external program called via Set value via = Program to return a calculated value to zenon and update the variable?
If so, where and in what form is the value expected?
Any clarification based on Engineering Studio / Runtime behavior would be appreciated.
