Good morning everyone!
I'm doing now in a project a navigation system, and I'd like to use the same frame for a set of screens, that all have the same width and different height. Is there a way to change the height of a frame accordingly to the screen that is been oppenned? It would also be enough to make the background of the frame/screen transparent, so I use an element as the background, so visually speaking, it seams as if the frame height is changing. I suppose it could work if it's programmed directly by Add-In, modifying the height every time centain buttons are pressed, but is there a more direct way to do it? As directly in the Engineering Studio?
Thank you all for your time.
