We are not able to communicate or even import PLC variables using Zenon 8.2 together with TIA Portal V17.
Siemens did release a new PLC that is able to use on both TIA V17 and V18.
We are using this PLC, with the guideline of the datasheet to use it inside TIA Portal V17, but it is not communicating with the PLC model 6ES7512- 1DK01-0AB0 inside TIA Portal V17.
Zenon version 8.2 with build 162748.
Datasheet guidelines:
Engineering with: STEP 7 TIA Portal configurable/integrated from version V18 (FW V3.0); with older TIA Portal versions configurable as 6ES7512-
1DK01-0AB0
