Distributed Engineering - Unable to publish the changes when connected through Zscaler Private Access (VPN)
We have Zscaler Private Access (ZPA) deployed as a VPN solution on all endpoints. ZPA works a bit differently from the traditional VPN solution as it does not assign any internal IP addresses. The problem in our case is that the user can not publish the changes because the database initiated connected is failing. Please suggest how we can resolve this issue.
