difficulties with autostart
When I start the runtime automatically with the PC through the autostart folder or through the run section in the registry, I sometimes experience difficulties with the dongle licensing or with the zenAdminSrv service. When I start the runtime normally after acknowledging the message, it starts normally. It does not matter if I start with or without the zenkeyblock.exe, to block system keys
This could happen due to a timing issue when starting Windows services and the zenrt32.exe or the zenkeyblock.exe. You can add a delay for starting the runtime, by adding an entry in the file "zenOn6.ini" [DEFAULT] STARTDELAY=5000 The value behind "startdelay" states the delay in ms.
This is a migrated post! Originally posted on 25.03.2008 by user markclemens. Please be aware that information can be outdated.
