DiagViewer: CT-type definition corrupted
Hi guys,
The zenOn Diagnostic Viewer shows my the following error text when starting the straton runtime on my PC:
>>> Project 'myProject': Expanding complex type for 'myVariableStruct' failed. CT-type definition corrupted.
The variable myVariableStruct is an array from user-defined data type (contains DINT, REAL, BOOL etc.) declared in starton and shared with zenOn (STRATON O&M for zenOn) to be display on the HMI. At the beginning of the project everythings were working well but since this morning I get this exception. Could it be that changing the user-data type after applying the property STARTON to the variable could be the problem? If yes, how can we "re-compile" in order to regenerate this CT-type definition?
Thanks a lot for your help!
Regards,
mariole82
This is a migrated post! Originally posted on 17.05.2018 by user mariole82. Please be aware that information can be outdated.
