Cursor and timestamp in extended trend
Hi,
I’m interested in how the timestamping on x-axis (abscissa) in an extended trend works. Does the timestamp of a following measured value change if there is no change of the measured value? I archive my data every 15 minutes. So when there is no change in value you see every 15 minutes a timestamp for the same value (Trend_no_change_1 and Trend_no_change_2).
What happens in between those 15 minutes? In Trend_change_in_value_1 you can see a change of the measured power from 720 to 750. After that I didn’t change the value, but the timestamp (two times after 11:30:00), but the cursor has still the timestamp 11:30:00 (Trend_change_in_value_2) until there is a change in value (happened in Trend_change_in_value_3) or 15 minutes are over.
I would like to know if there is a possibility to set the cursor to the right timestamp, so if the cursor is on 11:32:11 that date is shown and not the date of the last change or last archiving (not 11:30:00).
Thanks
This is a migrated post! Originally posted on 29.04.2019 by user ansiem. Please be aware that information can be outdated.
    Disclaimer
