Creating and Using Templates in Scada
Hello,
I create pages in Scada depending on the equipment used in the field. However, this situation becomes more complicated when there is a lot of equipment in the field whose data will be received. In order to solve this situation, I want to create a template and then use that template by generating it as an instance. Is this possible? How can I do this?
