Couldn't extend Runtime to 2monitors
Hi,
I just set up a new workstation and loaded zenOn projects into the machine.
I've changed the zenOn6.ini file, but when I start the RT, the display only shows at 1monitor only.
See the attachment for the screenshot. The screen size is 3839x1079. If you see from the screenshot, the RT only shoes at 1 monitor with half of the RT displays has been cutoff. This problem only happen at this machine.
What else should I check? I need your advice.
Thanks
This is a migrated post! Originally posted on 03.06.2011 by user nurul. Please be aware that information can be outdated.
