Converting of IEC61850 integer values into Bit wise
Dear
We have almost 900 IED in a project each having four function blocks to combine digital alarms and send it as integer value via 61850 to Zenon.
1-I need to know if Zenon logic has a standard Function blocks to reconvert the integer values back to bit wise that i can define them as alarms.
2-If with this number of IEDs, Do i need to run Zenon logic in a separate PC.
Example of the function block available in the IED, which convert 16 bit alarms into integer value.
Regards,
Adel
This is a migrated post! Originally posted on 28.10.2019 by user AdelGamal. Please be aware that information can be outdated.
