ConnectionState
ConnectionState
Hello, I try to visualize the state of the 61850 connection by means of a dynamic text symbol. The text symbol is set to present the limit text of the value of the connectionstate variable. The connectionstate variable has the rema "IEC 61850 Connection State". The problem is that the rema does not work online. (not in CEL/ALM display and not on dynamic text element. If I check the value in the statusdisplay then I can see the actual value changing accoording to the Rema (TCP-Connected en MMS accociated etc) Can someone help me Thanks in advance
This is a migrated post! Originally posted on 20.09.2017 by user Joulzer. Please be aware that information can be outdated.
    Disclaimer
