Engineers I require your support,
currently in the project we are working on we have two computers where a local SCADA is running with its respective CPU1 and CPU2 redundancy in (Zenon 8.0), level 3 reporting is required, this to two DNP3 masters with redundancy, the connection is made through a TCP/IP channel, Therefore, it is necessary to configure two DNP3 masters in each Process Gateway , could you guide us how to carry out this configuration
Thank you very much for your collaboration, we look forward to your response, good day.
