Configuring interlockings
Hi, we are testing the commands with the IEC 60870-101 Driver. The ON/OFF commands, configured with select and execute work perfectly but the interlockings don't work.
This is being tested with the standard template provided by Zenon.
We have configured an interlocking in the interlocking menu, where we survey the value of the variable (X01.Value = 1). This variable is assigned in the section "Variables" of the "Comand Group"
We force the value if this variable to 1 and when we select an action to perform a command, in the control box "Active interlockings" of the template does not appear anything. (We can only see the system interlockings like "Status already exists")
¿What's the problem?
Thank You
Regards.
This is a migrated post! Originally posted on 15.11.2012 by user knubla. Please be aware that information can be outdated.
