Command Sequencer
Command Sequencer
Hi everyone,
Small questions on the Command Sequencer topic :
1. Is it possible to have more than 9 steps in a command sequence ? The height of the windows seems to be limited to 11 cases, including the start and stop elements. So if I want a sequence to open 20 switches, it is not possible ?
2. The system i'm deploying has interfaces with other sub-systems, via an OPC UA Process Gateway.
My questions are, how can I let them order the start of a Command Sequence ? And beyond that, how can i let them know if a Command Sequence has succeeded or failed ? I would like to transmit them (via process gateaway) a variable linked to the sequence, stating if it succeeded or failed.
In advance, thanks for your help.
Maximilien
