Hello team,
I have used various versions of Zenon starting from 7.00, however, I have a query where, I can check my lot name history for it to be unique.
As per our customer's requirement, the lot name(which is combination of my "Batch name" and "Lot number") must be unique. I the versions older then 8.20 we had a VBA patch code developed that was helping us in the same. However, from version 8.20 the VBA support will be terminated.
Hence, is there any possible solution for the same where, I can check my batch history directly instead of writing any code.
